Iduino DUE
Warning: Unlike other Iduino boards, the Iduino Due board runs at 3.3V. The maximum voltage that the I/O pins can tolerate is 3.3V. Providing higher voltages, like 5V to an I/O pin could damage the board.
- Operating Voltage: 3.3V
- Min-Max Input Voltage: 6-15V
- Analog Input Pins: 12
- Analog Outputs Pins: 2
- Clock Speed: 84 MHz
Documents:
