BMA180 Triple Axis Accelerometer Breakout
Revision as of 03:57, 8 June 2012 by Admin (talk | contribs) (Usage)
This is a breakout board for BOSCH BMA180 digital triple axis accelerometer.BMA180 is a digital ultra-high-performance tri-axial low-g acceleration sensor for consumer market applications. It allows measurements of static as well as dynamic accelerations with very high accuracy. Due to its three perpendicular axes it gives the absolute orientation in a gravity field. As all other Bosch inertial sensors, it is a two-chip arrangement (here in a plastic package). An ASIC evaluates the output of a three-channel micromechanical acceleration- sensing element that works according to the differential capacitance principle. The underlying micromachining process has proven its capability in much more than 100 million Bosch accelerometers and gyroscopes so far.
The BMA180 provides a digital full 14 bit output signal via a 4-wire SPI or I2C interface. With an appropriate command the full measurement range can be chosen between 1 g and 16 g. A second-order Butterworth filter with switch-able pole-frequencies between 10 Hz and 600 Hz is included to provide pre-conditioning of the measured acceleration signal. Typical noise level and quantization lead – in 2 g-mode - to a resolution of typically 0.5 mg and a typical accuracy of below 0,25° in an inclination sensing application, respectively. The current consumption is typically 650 μA at a supply voltage of 2.4 V in standard mode. Furthermore, the sensor can be switched into a very low-power mode where it informs the host system about an acceleration change via an interrupt pin. This feature can be used to wake-up the host system from a sleep mode.
The sensor also features self-test capability. It is activated via SPI/I2C command, which results in a physical deflection of the seismic mass in the sensing element due to an electrostatic force. Thus, it provides full testing of the complete signal evaluation path including the micro-machined sensor structure and the evaluation ASIC.
  • Wide variety of measurment ranges (±1g, 1.5g, 2g, 3g, 4g, 8g and 16g)
  • 14- or 12-bit ADC conversion
  • 2 selectable I2C addresses
  • Programmable integrated digital filters (no external components necessary)
    • 8 low-pass filters
    • 1 high-pass filter
    • 1 band-pass filter
  • Programmable interrupt features:
    • Wake-up
    • Low-g detection
    • High-g detection
    • Tap sensing
    • Slope detection
  • 2 main standard modes: low-noise and low-power
  • Sleep mode
  • Wake-up mode
  • Self-test capability
Pin description
Here is the guide illustrates how to connect an Arduino to the BMA180 breakout board. The following is a table describing which pins on the Arduino should be connected to the pins on the accelerometer:
After uploading the sketch, in the serial monitor of the Arduino IDE, we can read the 3 axis data when it is placed vertically.
//BMA180 triple axis accelerometer sample code//
//www.geeetech.com//
#include <Wire.h>
#define BMP180 0x40  //address of the accelerometer
#define RESET 0x10
#define PWR 0x0D
#define BW 0X20
#define RANGE 0X35
#define DATA 0x02
int offx = 31;
int offy = 47;
int offz = -23;
 Wire.begin();
 Serial.println("Demo started, initializing sensors");
 AccelerometerInit();
 Serial.println("Sensors have been initialized");
void AccelerometerInit()
 byte temp[1];
 byte temp1;
  writeTo(BMP180,RESET,0xB6);
  //wake up mode
  writeTo(BMP180,PWR,0x10);
  // low pass filter,
  readFrom(BMP180, BW,1,temp);
  temp1=temp[0]&0x0F;
  writeTo(BMP180, BW, temp1);
  // range +/- 2g
  readFrom(BMP180, RANGE, 1 ,temp);
  temp1=(temp[0]&0xF1) | 0x04;
  writeTo(BMP180,RANGE,temp1);
void AccelerometerRead()
 // read in the 3 axis data, each one is 14 bits
 // print the data to terminal
 int n=6;
 byte result[5];
 readFrom(BMP180, DATA, n , result);
 int x= (( result[0] | result[1]<<8)>>2)+offx ;
 float x1=x/4096.0;
 Serial.print("x=");
 Serial.print(x1);
 Serial.print("g");
 int y= (( result[2] | result[3]<<8 )>>2)+offy;
 float y1=y/4096.0;
 Serial.print(",y=");
 Serial.print(y1);
 Serial.print("g");
 int z= (( result[4] | result[5]<<8 )>>2)+offz;
 float z1=z/4096.0;
 Serial.print(",z=");
 Serial.print(z1);
 Serial.println("g");
 AccelerometerRead();
 delay(300); // slow down output
//---------------- Functions--------------------
//Writes val to address register on ACC
void writeTo(int DEVICE, byte address, byte val)
  Wire.beginTransmission(DEVICE);   //start transmission to ACC
  Wire.send(address);               //send register address
  Wire.send(val);                   //send value to write
  Wire.endTransmission();           //end trnsmisson
//reads num bytes starting from address register in to buff array
 void readFrom(int DEVICE, byte address , int num ,byte buff[])
 Wire.send(address);            //send reguster address
 Wire.endTransmission();        //end transmission
 Wire.requestFrom(DEVICE,num);  //request 6 bits from ACC
 int i=0;
 while(Wire.available())        //ACC may abnormal
 buff[i] =Wire.receive();        //receive a byte
 i++;
BMA180 Triple Axis Accelerometer datasheet
Click here to buy BMA180 digital triple axis accelerometer
